Fry Rice Specialist
anyone that run the mn12performance solid rubber mount?
if you do how how are the reliability. is it a good piece or it will not last?
thanks.
They will last much longer than the factory hydraulic ones.
It is a compromise between factory and solid.
I wouldn't recommend solid motor mounts on a daily driver as they will rattle your fillings loose if you drive the car regularly.:boom:
Pretty car by the way Casper, meant to leave a comment but I got sidetracked.:hitit:
I have been running them for six months. Haven't broken them yet. I have done my best. Need more power!!!!!!!
Brad
Fry Rice Specialist
and it's ok for the motor to be raised up about 1/2" over stock right?
i try it just now and notice the solid rubber mount is higher about 1/2" than the factory one.
Fry Rice Specialist
thanks a lot for the quick reply...back to work.
