One of the things that I would like to do on my 92 5.0 H.O. thunderbird is take out the foot E-brake and put in a hand brake. Has any one done that mod yet. If so could you like me to some pics or maybe even a how to forum.
Thanks
Chris
Thank you i can belive i missed that
Refrigerator Raider Hater
One thing not mentioned in the article is you may need to drill a hole for the cable. 1 1/8" IIRC. Needs to go on the inner lower driver's corner of the back seat. You may want to lower the gas tank whether or not you drill, as the cable needs to snake between the tank and unibody. Also, you may need to partially unbolt your dash in order to completely remove the foot brake assembly. If you want a dead pedal, now would be the time to install it.
