Alright guys, I've been driving a 1990 F-150 that is laying around at work, and last night I had to park the truck on a hill, so I put the parking brake on.
I go to leave, and it's stuck.
I did the obvious try to go into reverse and hope it snaps back, but no.
What else should I try? Will cutting the e-Brake cable release it?
Also, what is a good way to see which is which, or by feel? I cant SEE which brakes are which, the wheel is in the way, and I cant jack it up, since it's in mud and on a slight hill.
What would I need to cut it, and how can I tell for sure, BY FEEL which cable is which. Brake vs Ebrake
Thanks
Before you go cutting any cables, check to see if the lever came disconnected from the release. If so, you should be able to get a pair of pliers in there and pull on it to release the brake. Cutting the cable would be a last resort, and it might not even work depending on where it is stuck.
Mike
Refrigerator Raider Hater
release the handle/foot, and just pull on the cables from under the truck. that's how I did it in my bird.
the handle/foot does not release.
The harder I press on the handle/foot it just goes down and down. Although I was able to pull it up a little bit, but not enough.
Sometimes the Parking Brake light is on, sometimes it isn't, but those tires don't move when in Drive.
