Refrigerator Raider Hater
E10 is a poor performer in every respect I know of, find the nearest E0 station near you:
http://pure-gas.org/
I guess my e85 vehicle isn't going to be warranteed. Oh well.
I need more details.. what systems will be damaged?
On Probation
e10 dries out gaskets and causes corision on alluminum and absorbs water out of the air and corodes fuel systems from the inside out.
My 95 cougar has been running e85 since nov. 2008, no issues with any fuel system parts. Only mods. to the fuel system is fuel pump and injectors.
Blown 96 please don't give bad information for our vehicles.
Vehicles built since 1990 are able to use fuel with added ethanol.
Methanol is the corrosive alcohol, not ethanol.
On Probation
I am talking about gaskets on my drop hoses and gaskets in carbureators like on lawn mowers, and any carbureated engine. It really dose pull moisture from the are and can carode your fuel system.
E10 in an open gas can absorbes as much moisture as e-0.
Ethanol does not corrode aluminum engine parts.
Ethanol does break down fiberglass fuel tanks in older boats.
My side job was a lawn business when I was working on the fire department.. Never had a fuel related issue with the equipment.
New rubber hoses and components are made for using alcohol enhanced fuels.
E-15 won't be around for a while.
