1 - 20 of 26 Posts
Has anyone tried these plugs out yet? are they even worth buying or should i just stick with the regular autolite plugs?
Any info on these would be great
I'm wondering the same thing...
Don't waste your money. Get Autolite or OEM Motorcraft. As another, much more experienced member here once told me, unless you have a blower, nitrous, or some serious tuning, debating spark plugs on a stock 4.6 is futile. Personally, I use Autolite AR764's. I check them every 10,000 miles. See this thread.
I'm runnin motorcraft platinums right now..
Waste of money. Double plats or copper are the way to go.
I use those Autolites too!
They are pretty good so far. Little to no electrode wear so far after 10,000 miles. They are just white.:rolleyes: They are lasting longer than I thought they would. I thought coppers were done by 15,000 miles. Hell, I had to open the gap by a thousandth or two on a few. While we're on the subject, anyone else's plugs coming out frosted white while running on 87 unleaded with the 10% ethanol mix? I'm pulling over 21 inHg of vacuum, so I couldn't imagine there being a vacuum leak somewhere. Besides, I replaced all of the under hood rubber tubes a little while back. MAF is clean, no codes at all. I wish I had a scanner so I can see the LTFT's and STFT's.
I agree, don't waste your money. I had them and didn't notice any different than the stock plugs, power or gas wise. I even had to replace one because it went bad after 2 months.
Mike
My plugs are like that, too. I always thought maybe new O2's might change that, but the Bird runs great and gets good mileage so I leave stuff like that alone. You got a pic of your plugs? I'm running Autolite plats in mine and I'll get a pic of my plugs - they've been in over a year and a half now with about 15K miles.
Yes, I actually do in this post. I did replace my original O2's about 2,000 miles before that picture was taken. My dad, an experienced mechanic, says it's because of the ethanol, which is causing me to run a little leaner than usual.
High-Mileage 4.6L Thrasher
Those look normal for any fuel injected engine that's running properly.
JL
JL
Even with a frosted white electrode like that? Guitar Maestro said it looks like it's running too lean like I have a vacuum leak. So maybe it's nothing to worry about for now? Either way, I'm swapping in a PI intake manifold! :D
My plugs have had that coloring every time I've pulled them.
JL
Spark plugs are spark plugs. I use the Motorcraft Platinum in my T-bird. I will however upgrade to Bosch plugs for my PI Teksid once thats finished but I am also going to be running a decent shot of nitrous.
1 - 20 of 26 Posts
