I saw this old 429 engine from an early 70's truck. Is this not a great motor to rebuild for a Cobra? The motor is out of the vehicle and the guy that has it says it came out of a truck or t-bird. Clearly he has no ideal and who knows what it needs.
not exactly true.....my 73 bird has a 460 in it.(if you were referring to all 70+ model years)SCTbird1994 said:429 is a great engine if its one of the very first years it was made (68-72). I think after 72 they didnt have as much compression and lost alot of horsepower.
Check the casing number on the heads / block. Make sure its not a 460 since they have the same exact block. The TBirds came with 429's at that time.
- Dan
okay...gotcha.SCTbird1994 said:Yeah I was talking about the very first years the 429 was made. After that they changed the deck height on the block and lost the 11:1 compression.
- Dan
I agree. Big block Fords suck wind.icantdrive55 said:I think a stroked smallblock would be alot more fun in a Cobra. If you are just after the wow factor get the big block.
Its been done.....Jimbobicus said:I'd put one in my Bird, but shoehorning an engine that big in.... wow.![]()
