Here’s a big old thread on SVTp that discusses some of the cons with the true trac.
I have a Eaton/Detroit True-Trac in my car, I am also using Alum bushings. I am trying to see if this is normal operation or if its a problem with the unit. Beause of the Alum bushings I can hear everthing that happens back there. I am using 80W90 oil from what i remember...
www.svtperformance.com
If you’re still building the car for top speed it really doesn’t matter what you’ve got back there. Personally I have never been able to justify the expense over the Ford Trac Lok setup, even though a Torsen remains on my wishlist (along with a Kenne Bell, Delrin bushings, forged wheels and a paint job, eg the nevergonnahappenyacheapskate section of the list lol). Set up the clutches in the alternate stacking or at least use the thickest shim packing (if you can’t find any good used extra clutches for the alternate), and be sparing on the friction modifier they work pretty well..
The primary complaint seems to be noise.
The benefits seem to be that it stronger, smoother, gets better traction,and is maintenance free.
So, for a track setup it seems like a good plan to use the TrueTrac with non-synthetic oil as soecified and keep the TL in the street setup.
Our only way to test the car is to use the drag strip, so we need the LSD.
Prior to the traction Lock, my car was not capable of leaving.
It either spun one wheel forever or the Traction Assist would shut it down if engaged. The TL unit changed the car dramatically for the better, ditto for the 3.73 gear set
At the very least, it's a good LSD for a bargain to me. Thanks for the help.
