Motive gears are decent gears but you'll need to be able to calculate pinion depth from their measurement. As he stated the 31 spline will not work and the axle seals and bearings will not work either.
Alan
Supercoupeperformance does I have gotten a couple from him.
Or you can compile the parts yourself through summit.
Alan
i didnt want to start another thread so ill piggyback a little (not trying to hijack :tongue: ) but my car has a bad clunk when driving only when in gear and when i do a burn out it'll only leave one mark now where as it used to be both as it should is the kit for the re-build from scp a good choice or would it be cheaper from summit? thanks
The question is did your car come equppied with a traction lock differential? Bill's deal is fair I'm not sure what summit charges ,but if you don't have a traction lock you will need one of those as well. You'll also need to have the diff built it is not a job I suggest for those who are not experienced with it.
Alan
