I wasn't sure wether or not to put this here or the tuning section, so here goes:
When the computer sees that the TPS is at WOT, does it have any effect on the IAC?
I'm having a problem (Last two days, and occasionally throughout the last year I've had the car) when I hit wide open throttle for a while, and let off, and go back to a stop, the car still wants to haul ***. It's sitting there at 1300 trying to pull away with both my feet on the brakes.
It happened this morning again, and I pressed in on the Get-Loud pedal to make sure it wasn't the throttle cable sticking, and it revved up to 2k (Tires spinning) and then settled back down to the 1300.
What I'm thinking is either the TPS is going out, and making the car think its at WOT, and holding the IAC open (If it can even do that) OR the IAC is sticking open for some reason.
Ideas?
Ah, Sweet, I'll replace my IAC ASAP then :)
Cheers!
-Ryan
