1 - 20 of 39 Posts
Ok, I know how some of you feel about "fooling" the ECU and that the proper way to eliminate the EGR is programming, but here is a cheap and quick circuit that will eliminate both your EGR valve and DPFE sensor WITHOUT triggering the Malfunction Indicator lamp. Someone else has a variation of this circuit on their Ranger and claims a 5-10% increase in gas mileage with no MIL, so I'm willing to try it at least and I'll let y'all know the results (2-3 mpg sounds exciting to me).
I know the power resistor pack I have is kind of ugly, it's just you have to have a 33 ohm resistor capable of dissipitating at least 5 watts (so I recommend you use a 10 watt). Well, I didn't have one of those, but I had some 10 ohm resistors so I strung three of those in series. If this thing does work, I'll put together something nice, pretty, and plug-n-play for a permanent installation.
The way this works is the transistor switches on and off so the ECU sees the correct feedback signal from the DPFE circuit (which is about 0.5v with EGR closed and 5v when open). I haven't tested it yet (I just put it together), but I will post the test results and if the EEC is fooled or not.
I know, I know (Daniela tells me all the time), I have too much time on my hands..... :D
Happy Holidays!
If you got a proper tune you would realize this benefit and much much more. The reason the fuel economy might go up is because the pcm commands more spark advance when there its egr flowing into the engine; it has the same net effect of increasing spark advance in the low load/low rpm range.
did it work?
I built your circuit but have not tried it yet just in case it fries a circuit in the pcm and i dont have a spare. I put new heads on and removed the egr blocked the port and removed the pfe so i can get to the plug. Right now everything is plugged in normally with no exhaust gas going into the intake and no flow through the pfe. I threw a code 1407 not sure what that was but nothing for the egr circuit yet.
I want to try your circuit but not sure how it controls voltage as the engine runs. Seems to me that it would only put out 1 voltage signal and not vary the voltage like the existing system does by vacuum and exhaust flow. If the pcm see a 1.5 volt signal all the time it would likely cause a problem in either idle or wot. The same thing if it put out 5 volts all the time. When the pcm runs its checks it will pass till the last test and fail causing a disregard egr circuit. I have read this does not affect timing even though i notice lower mileage when the egr is clogged and the no flow code is in memory. I can clear the code with my scanner but I cant reset the pcm to disregard egr permanently. I think if you remove the egr you should do this, but I don't know any shop with that capability around me.
I am anxious to hear your results.
Well, I haven't tried it yet because my gf is going out of town with the Bird next week, and I didn't want to disturb anything right now. The car gets 26-27 mpg right now, runs good, and no MIL. I'll test it and let everyone knows how the testing goes when she gets back (she'll be gone the whole week).
I've actually been thinking about it, and I'm going to try the circuit first just leaving the original EVR in place (not using the big resistor) and just eliminating the DPFE. And yes, I realize that the voltage it's just going to toggle between 0.5 and 5.0 volts, but the EEC should be just fine with those responses/inputs. Why don't you just hook yours up? I assure you the transistor isolates the input from the output so you aren't going to fry anything if you hook it up right.
I could actually see this being useful for passing emissions in conjunction with a tune that eliminates the timing changes due to EGR opening. In NJ, for any car 96+ they don't use a sniffer at all, they just plug into the OBD2 port, and if you have no DTCs and no more than 2 readiness monitors not ready, you pass. As my car sits right now, I have the EGR turned off, so my EGR readiness monitor always shows not ready. Emissions-wise, the rest of my car is stock, but for example if I were to delete the rear O2s and the smog pump, my car would now show 3 readiness monitors not run, and I would not be able to pass emissions, even though everything would be working properly in the computer. So a simulator like this would allow you to leave EGR turned on in the tune, not get a check engine light, and not have a readiness monitor continually not run.
That is why I have my rear o2 sensor eliminators instead of a tune to delete them.
I have the p1407 code right now which is no flow detected. I have the connectors hooked up as normal with the egr bypassed with plate. Tomorrow I will try and connect the resistor pack and see if i can get the code to go away. I am also running in open loop not sure why yet. I run hydrogen so I installed a O2 adjuster for the front O2's. It may be adjusted too far out right noe because I don't have the hydrogen running yet. As far as I know the p1407 will not put the car into open loop so it must be the o2 adjuster setting. Hopefully I will have this figured out tomorrow. Got my fingers crossed.
I did the tests today. The 1407 code went away for a while and then it showed up after the 3rd key on event. I changed the wires around on the connector since my wires are a different color code and drove some more. I got a 1401 code then meaning high voltage dpfe. I switched the wires around again since i have never had this code and noticed a resistor touching another resistor lead. I separated them and ran several more key on events and after 4 there is no 1407 code. So far so good. I am only using the dpfe part of the circuit since the solenoid can operate normally without egr being active.
My open loop was caused by my O2 adjuster being set for the hydrogen. I turned on the hydrogen before I started testing today and the car went into closed loop instantly. The O2 sensor was set too sensitive without the extra oxygen supplied by the hho unit. I had already had this adjusted prior to rebuilding the engine and it operated the same way as before once it was switched on. My average mileage was 20 yesterday and 23 today. This is still a little low from my previous testing, but not bad for starters.
I will continue to monitor the cel and see if it comes back on with the 1407 code which this device should fix. As far as pinging or rough idle there is none. If the mileage was hurt from not having egr gasses taking up space it was compensated for by the hho improving combustion. Now to see how long it will go before throwing another egr code.
Discussion Starter #14
WhooHoo!!! Glad to hear it works and the problem you were having was a short in your circuit! That is awesome news and thank you for sharing!!! :thumbsup:
Ok, I put it in a pretty box now!
I started building these circuits and putting them in relay boxes; they look so much nicer and protected now!
Now when people get the kit from me, it comes with:
Circuit Enclosed in relay box
4 Splice Connectors to connect to existing vehicle wiring
Tie-Wraps
Instructions with Diagrams and Photos
Here is a recently completed unit:
Here is the connector view:
Here is what is inside the box (it's the same as the circuit in the first set of pics above):
Eventually, I'd like to build them inside the DPFE box so it looks stock on the automobile!
Discussion Starter #18
and how much do you think it would cost?????
I don't know, I've been charging $45, but it may fluctuate if my costs do.
1 - 20 of 39 Posts
