I need to replace my EGR sensor cause it'd only reading 4.8 volts. I can see it in the back of the engine bay. It's a pain in the *** to get to. Is there any easy way to get it off I can barely reach it. I appreciate all who read this I can be reached at [email protected] Thanks
Nick in St.Louis
P.S.- GO CARDS!
today i had the tranny out, the egr looks quite easy to get to that way :). just kidding, id probly remove the TB and elbow, maybe the exhaust..
Well, first of all, I would remove the windshield wipers!.... This allows the removal of the plastic panels below the windshield, and, and the rubber moulding that further obscures things.... there is still a plastic mating lip, but for what reason I cant Imagine ...a little judicious cutting on that will yield sufficient room to get at things...Also remove the hood struts, then prop the hood more vertically(this doesnt give any more room , but a lot better angle)...If you can find a friend with real little hands that also helps
