1 - 19 of 19 Posts
Hi I'm stuck in a situation rigth now I try to replace the egr valve and sensor but I see is a little complicated to do I try to remove the intake manifold to take it off (and put a new intake gasket too) I take almost everything from the top of the intake(gas line,t.b. cables, injectors conections) but still a lot wirng left some are conected to the a/c compressor so I leave it on I take all bolts off but I can't gain acces to the valve o take the manifold so any help is welcome.
it's a pain,,,i did mine a while back..i ended up taking off the cowl piece then the upper intake elbow. that helped alot... jus takes patience..
x2 on this. I'm in the middle of a PI swap and all I have left is the egr to remove. I'm considering leaving it on because it looks like a pain to remove. any tips?
Well I read the haynes and they say to lift the car and unbolt the egr but how they are thinking? My hands do not fit in there can you tellme the easy way to unbolt the valve?
where are u at so far in the process?
I already take all bolts from the intake and unplug two I guess 1/2 inch hoses close to the valve I can move the intake but something is holding the intake I think is the rgr valve
the e g r has two bolts holdin it to the back of the in take.
They are easy to reach?
not really,,, u kinda have to go by feel or i did anyway..
I'm goin to try after work and I let you know thanks in advance
hey no prob let me know how it goes..
Ok finaly I take the intake out but it was hard I have to take the wiper cowl off to gain acces to the 2-10mm bolts from the egr valve but first move the 0 clamps from the heater hoses and the 2 fat hoses from the egr sensor and take the vacum egr selenoid out that way you can stick your hands and a 1/4 racthet with a long 10 mm socket to release the intake and the egr valve is there easy to remove well I didn't. Do it yet but I was checkin the manifold elbow and I see I can remove it to later install the valve easy so I take the elbow off and I notice betwen the elbow gasket and the manifold is a cut to let pass I guess gas from the exhaust from the egr and the other part I don't know what's the name of it but it have 3 cuts but they were clogged they were very dirty
yep they clog up and get the egr clogged up too sometimes, make sure u clean that out real good.. sounds like your doin good so far..
Discussion Starter #15
Jajaja always is easy to take everything apart the challenge is when you have to put everything together again. One more thing what else you recommend to replace now the I have the intake out? Cuz sometimes I noticed the exhaust gas smell weird
IIRC, I took my valve off the manifold before I pulled the manifold out when I did my conversion; it was easier that way than trying to get that EGR tube off with all that room in there. I believe I used a 1/4" inch drive with socket & a wrench to remove the two EGR bolts. The EGR tube on the 94-95's is pretty short.
Discussion Starter #17
Houston we have a problem!! I bend and broke one of the little pipes from the main egr valve tube to the egr sensor and I cant take the tube from the exhaust is any kind of glue I can stick that the pipe still there with a bend little hole
hmmm,,well if u can get it out u could probably get it rewelded.. but it would be alot easier to work on if u can..but i would take it out and either reweld it or use some j.b. weld
Discussion Starter #19
I'm going to try it thanks if doesn't work I'm going to take the engine out and fix some other leaks.
1 - 19 of 19 Posts
