Trying to figure out why Shox.com indicates that the Eibach Pro Kit and other drop springs for T-birds and Cougars are "not for SC" or "Does not fit the SC model?"
I'm pretty sure people on here with SC's have the Eibach's on their cars?
Thanks if advance for any input.
Gary
89 SC
Eibach makes 2 different sets of Lowering Springs for the MN12 Thunderbird/Cougar..
1 set is for the V8/SC Thunderbird/Cougar Part# 3524.140
The other set is for the NA V6 (Non-SC) Thunderbird/Cougar Part# 3522.140
I havn't checked Shox.com, but I'm sure the set they sell there...
Are for the NA V6 (Non-SC) Thunderbird/Cougar..
That's probably why you're having an issue..
If you have a V8 or SC Thunderbird/Cougar..
Make sure you use Part# 3524.140... or.. You could have issues with your front end being too low..
Wow- Thanks!
Eibach makes 2 different sets of Lowering Coil Springs for the MN12 Thunderbird/Cougars..
1 set is for the V8/SC Optioned Thunderbird/Cougars
The Part # for the Eibach's used on the V8/Supercoupe optioned Thunderbird/Cougars is: 3524.140
The other set is for the Naturally Aspirated V6 optioned Thunderbird/Cougars..
The part # for these is: 3522.140
I havn't checked their website, but I'm sure the set they sell there are for Naturally Aspirated V6 optioned Thunderbird/Cougars..
If you have a V8 or SC Thunderbird/Cougar make sure you use the "3524.140 part #" or you'll issues with your front end being too low..
Thanks for the info!!!!
