1 - 2 of 2 Posts
Problem 1 - Is there anything that could come out of adjustment on the power door locks on a '97? The lock on the drivers side on mine seem to be weak. Most times, whenever I go to use the locks, either by the button inside or the keyless, to either lock or unlock, it takes several pushes to get the lock to actually lock. The motor is turning, but is sounds kinda weak.
Problem 2 - The keyless entry itself is sometimes hit and miss. Sometimes, the remote will just spontaniously not work. The batteries in it are new. This is alost always intermittent
1 - 2 of 2 Posts
