Is having your electric fan turn on at 185* and off at 165* too cold for the engine. I already have a 180* Tstat installed if that makes a difference. Need the help on which relay kit to buy. Thanks.
What's the recommended temp. setting?
PostSkank
mine is on at 200, and turns off at 180
I dont believe having the fan running while the thermostat is closed will do you too much good as flow is minimal. Please correct me if I'm wrong
The t-stat is not open below 180 when the fan is still trying to cool to 165.
