How many fuses/relays are connected to the fan(cooling). I know there is going to be relays for the air conditioner and for kick-on but what else is there?
EDIT: OK maybe I haven't been clear, I checked the fuses and ran power to the relays and everything seems fine but the fan still dosn't kick on....a sensor or something maybe?
Thanks
bad fan maybe?!
MG
(to tell you the truth, it probably lost its ground... happens a lot)
yes there is a coolant temperature sensor that tells it when to turn on.
I just figured out that the fan kicks on with the air conditioning, I haven't had the car hot enough yet to see if the fan comes on without it.
I'm wondering if the thermostat is sticking, any ideas?
Thanks
Chapter Director Coordinator
if tstat doesn't open at right time then fan won't kick on and car would overheat no?
i agree though.. on a stock tune, my car will run warm unless A/C is on to kick the fan on...
