Why not just repair the wiring harness?
Is first gear otherwise thrashed or is it still a good tranny?
sooo.........look at my homepage in my profile. there aren't any center consoles designed to work with a hurst v-matic 2 ratchet shifter but mine seems to.... its just a matter of getting some fiberglass, small pieces of aluminum from lowes, and getting creativeThe_Ghost said:-_-
ps.
porky, i am dying to do a 5-speed swap. this car would have huge balls if it could just be a 5-speed.
unfortunately 94-95 5-speed center consoles are quite a rarity and unfortunately, quite costly.
What I want to do is be able to cruise around in 4th gear at 800rpm like I used to.
This motor's got the torque for that.
Yeah, don't do that...cougar man said:You could get a Baumann TCS controller which allows you to have a full manumatic-style control that turns your cruise control buttons into "paddle shifters." They aren't cheap, but you do get to reprogram shift points, torque converter lockup, and all sorts of good stuff like that when using it as an automatic, with the added bonus of the full manual control.
http://www.baumannengineering.com/tcs.htm
hotbird said:Well, yes you could technically control the solenoids with switches, but it would be quite the PITA while driving. Both solenoids off=2nd gear. Both solenoids on=4th gear. Either one or the other on or off make first and third gear.
That said, if your harness is fixed as you say, and the trans still acts like that then it is probably fried and needs a rebuild.
VicRattlehead said:you can get a chip tuned to lock the trans in gear.
manual 1 = 1st
manual 2 = 2nd
D w/ od off = 3rd
D w/od on = 4th
no down shifts or up shifts unless you move the gear selecter.
