This one has totally got me lost. My car is throwing code P1000. It says emissions test incomplete. And my snap on code reader says that this is due to not every check in the emissions system being executed (or something to that effect). I discovered that the check engine light itself was removed :) I replaced it and viola! it is lit up. I don't have any ideas onhow to fix it. Thanks
-Rob
theres probably nothing wrong with the car, try resetting the computer by pulling fuse 15 under the hood (some say to try to start the car with it out) and plug it back in. after that, let the car idle for a bit, then do some normal city and highway driving to let the computer relearn. if the code comes back, then try to look at the cause
there id def a cause
it keeps coming back after clearing codes. what should i do guys?
