1 - 12 of 12 Posts
shaken, not stirred
IDK why but everytime i get above 4000 RPMs my motor makes a noise like a tinging noise, or maybe somthing loose. But it is definitly a metal noise. My other 94 bird made the same noise, i just thought it was a tired engine when it made the noise around 160k but this engine only has 77k on it. Any thoughts? I am sure this maybe a common problem, but you really got to know what your engine normally sounds like. Other people i ask to listen for it never know what to listen for. thanks
C.Hill
Does it sound like a bunch of ball bearings rattling around in a coffee can? Sounds like you've got a bit of detonation going on there.
-Rod
shaken, not stirred
-Rod
Yes, i was trying to figure out the best way to describe it, and that pretty much sums up the sound.
C.Hill
Try some SeaFoam to clear out the carbon build up in the combustion chamber. Also make sure there are no vacuum leaks and that the MAF is clean. Could also try resetting the computer. Another alternative which doesn't fix the root problem is running higher octane gas.
shaken, not stirred
I think i have heard of SeaFoam on here before, but what is it? Any other suggestions?
C.Hill
pull off the spark output plug by the maf sensor, fixed my pinging until I can replace my o2 sensors.
ok when i buy seafoam should i put, in the gas tank, oil and brake booster?
i heard the gas tank method is for cleaning the injectors, the brake booster is for cleaning the cylinders ect....but what does putting it in the oil do?
and i will be giving the car a tune up right after the seafoam
Faster than Porkchop
brake booster for upper intake down , in the oil for the internals .
shaken, not stirred
:zwthstpd:
Ok thread stealer, I still need to konw what this seafoam is and what it does and where to get it.
C.Hill
C.Hill
When I first got my car the car would ping (detonation) .
I fixed it by cleaning the Maf sensor wires .
http://tccoa.com/articles/intake/mafclean.html
The seafoam is used to clean
carbon build up and stuff . You can find it at most auto parts stores for about
5-7 dollars . Its kind of like a detergent , you will have smoke and the neighbors
are not going to like you for that moment till it burns all the carbon .
You can put it in the oil , in the gas tank and through the brake booster hose .
shaken, not stirred
hey sorry for stealing your thread man, i just had been wondering about what it does on various parts of the motor
and thanks to everybody that helped
I was just kidding, ain't no thing.
C.Hill
1 - 12 of 12 Posts
