I have a '95 TBird 4.6L. A week or so ago my engine started overheating. I pulled over filled it with water to the coolant level line and then took it to a local shop. Informed me I had a cracked lower hose and replaced. Fine. Next day driving it the car had a rough idle and started to shutter. All of a sudden all power shut off. To restart car had to give it alot of gas. Took it to another shop where they informed me i flooded cylinders 3,4,5 and my crankcase. Also informed me heads were warped but not cracked. They said complete overhall around 3k, or new engine 6k. I'm a college student so those prices are a bit out of reach. Plus I'm pretty sure I can do it for much cheaper. Even thought about swaping in a 5.0L, because cheaper and easier to work on. What does anyone recommend that I can or should do? Any help would be helpful.
That sounds like it could have happened.
For $3k you can get a new 99 PI motor installed. $1,500 motor and $1,500 installation and materials. That is if Ford did not raise the price in the last couple of years...
You have the following options:
1. Buy a used motor from a junk yard. Of course you risk getting another lemon. You can always ask the Junk yard for a guarentee.
2. Take the heads off and see if you can get them fixed at a machine shop and re-install them.
Either of the above will take about the same amount of time.
Good luck.
Ok look you seem to need this more than I do. Give me a shout at
and I'll see if i can help you.
Mike
Man, the level of specificity of that diagnonsis?? There's no way they can know what they're taking about! (I mean, that would have cost them $$$ to diagnose!) I want a second opinion.
