just wondering if anyone knew why or had this problem, my cougar revs up and down sometimes when i start my car goes from 500 to 1500 then back down then up etc.... but its fine as soon as i put in in gear
Reset your computer by pulling the negative terminal. Could be a problem with your idle air control too.
It could be anything from your AIT to your ECT. It sounds like 1 or more of your sensors is reading incorrectly sending incorrect info to its ECM. It could be that one of your sensors is dirty or malfunctioning(double check anything electrical).
Sounds like what mine did. Try a new MAF( I know they aren't cheap) and a new IAC. (Also not cheap) If not? Then you have a faulty sensor somewhere. Reseting the PCM will only keep it away for awhile. Check the ECT and ACT. Good luck!
motor city poster
my car will just do that for the first couple times after disconnecting the battery or when the battery has a crappy connection.... its always worked for me
