I heard somewhere that when you put a flowmaster on, the engine will run warmer. I forgot if he said just for a little while, or forever....
But...I put a flowmaster 40 series muffler on my car Friday, and on the way home I noticed that my temp gauge was higher than normal and the oil pressure was a tad higher also. The weather was low 50's and rainy.. Now, last night i drove about 30 miles in the same weather conditions and it didnt heat up at all. Was I just seeing things, or was the comment about the flowmaster really true?
Thanks
I dont see how that can have any effect, if anything a tiny minut lower temp of like a degree or something from more flow and less time for the exhaust to heat but just a muffler wouldn't make that difference
would glasspacks and removed cats?????
make the car run warmer b/c mines is, i gutted the cats and i have dual glaspacks and my car will run to the R in NORM. I think it might be the gutted cats.... but hey more flow right????
Marvin M.
Running gutted cats and glasspacks, you are looking forward too some burnt valves....
What causes the valves to burn? Is it the gutted cats or the glass packs? I have gutted cats, and just replaced the large cat with a high flow cat and dual flowmasters......am I ok or do I run the risk of the burnt valves also??
I had flows put on my car and have been noticing it getting warmer in temp. I only started to notice it on my trip back from Missouri. My temp gauge has been peeking over the half-way point a couple of times in the last week. I have a new thermostat to put in when i have a chance. I dont know if this will help at all.
Anyways , mine has been getting warmer also and with the temp's in the morning you wouldn't think it would get that warm. 50-65 degrees in the morning in Oklahoma
