I have noticed every year in the summer weather that while riding in the city with the a/c on, my temp needle stays close to hot. My fan works, I have plenty of coolant. What can I do to fix this, I noticed the same thing on my mom's 96. My wife has a trailblazer and you can park and leave the a/c for a long time and the engine not get hot. I put a tranny cooler on last week while I was having my tranny rebuilt. Is there anything at all, this is frustrating when you cant run your a/c when the temp is above 80degrees outside. We have bad humidity and heat in west TN.
Have you tried a bottle of Water Wetter? Royal Purple also makes a coolant additive...The Water Wetter seems to do the trick for me.
joseph
Make sure the radiator fins are cleaned out. Do a flush and refill.
Take radiator to a shop for professional cleaning and rodding. Costs about $35 here if you take just the radiator in.
Upgrade to double core radiator. I THINK the 03 Cobra one works, but have to buy fan shroud and pigtail also. It doesn't have a built-in cooler, but you have and external. You'll have to do a search to find out more.
I just did the 02 explorer swap and had my stocker cleaned and rodded and it works great. I have yet to get above 1/4 into the normal range under any condition. We have about the same weather here (90s with 90s humidity).
Hope this helps
Rob
I think I will do the clean and refill first. I have never cleaned it, it probably has some buildup in it. I saw and ad for water wetter somewhere, mayber 5.0 magazine or spike tv. Thanks for the help guys.
Advance and Autozone also sell the Water Wetter, same price as Summit Racing. Under $10.
If you end up needing a new radiator, I got mine cheap, and brand new, from www.radiator.com . Made by the same OEM supplier that Ford uses (Visteon).
