1 - 12 of 12 Posts
Hi everyone, I have a small problem with my cat. When i start it up the engine shakes even after it has warmed up, i have checked the plugs and they all are in good shape no fouling or anything else, gap is good on them. Also when driving down the road you can feel what i call a miss every so often, plug wires seem to be in good shape although i haven't changed them in about two years now. Any ideas what might be causing my shake and miss?
vacuum or mount? maybe?
Mounts are good. As far as a vac's maybe, I don't hear anything like it would be sucking air. But will check vac's again.
i was thinking engine mounts too. maybe trans mounts? try cleaning your maf, check your distributor and rotor, change your plugs and wires....
i have to change my motor mount and trans mount, but it doesn't "shake" at idle. it does at speed when i let off. i think you have a vac leak somewhere. clean the maf (or unplug it) and see what that does.
How do you know they are good? I thought mine where good until I replaced them and one fell apart in my hand as I was pulling it out from under the car.... :eek:
Might shook at idle too.
hey, white lincoln, how hard were they to change with engine in the car? specifically the pass. side. thanks
Might verify that the harnesses going to the injectors is firmly connected.
mine shakes a little bit off & on at idle or startup, most everything is new i wouldnt worry too much about it as long as its not excessively bouncing around. just think of it as a massage chair :D the warm startup & bad idle, it must be a ford thing have a friend with a 92 f250 with a 351 and it will do a little shimmy randomly too
Ok well i have checked every thing I know on this kitty, so i wont worry to much about the little shake at start up, what does concern me is the miss feel i get going down the highway, any suggestion's on that? And thanks everyone for the input.
Dartanion, I think our Cougars are related. Mine has a shakey idle and when at hwy speeds it feels like the power comes and goes. Only 46,000 miles.
Well we could be kin, Since i posted that. I have done a few few things to the little kitty, the ignition coil was replaced and i replaced the plugs and wires yesterday so far the shake and the power that came and went at highway speeds seems to be gone now,she is purring like she is suppose to. Maybe try these things and see if it helps.
1 - 12 of 12 Posts
