· Registered
Well it seems like it is one problem after another. Now my wifes SC is stalling occasionally. Weird thing is it fires right back up again. It runs fine, then sometimes it idles really weird. A local mechanic recommended replacing the ICM, Coil Pack, Wires, and Plugs. So I figure I will take on the ICM and Coil Pack next weekend. I ordered the Screamin Demon pack from SCP. I was just wondering if anyone knows the specifics of replacing these things. I mean obviously it looks like you remove for little bolts and swap. But I want to make sure there isn't anything else that needs to be done. Also any insights on what may be causing this would be great. I don't mind replacing the little things bad or not since the are all original anyway. Also how hard is it to replace the Injectors on these things? I have replaced them on my 5.0, but looking under the SC's hood kinda scares me!
· Registered
Discussion Starter · #3 ·
well I found the problem, somehow the vacuum line came off the fuel pressure regulator. So not only did I have a nice vacuum leak but I was also missing the regulator. Hooked it back up and now it runs like a dream.
· Registered
Discussion Starter · #5 ·
Why? are the coil packs bad? I figured I would replace it anyway since the previous owner didn't take the greatest care of the car.
