1 - 2 of 2 Posts
Would it be less work to swap the front sway bar while changing out my engine mounts? Don't tell me yes just because I will "have it on jacks", it only takes a few minutes to do that. I mean, is unhooking the motor mounts a way of making the sway bar install simpler?
P.S. I planed on installing the oil filter relocate kit and a tranny filter.
I doubt it. Pulling the engine would make it easier. There's really no way to slide in a larger diameter swaybar, you have to either drop the K-member or pull the engine. I've decided to leave it til my engine swap and save the headache.
1 - 2 of 2 Posts
