1 - 2 of 2 Posts
I'm stumped, I checked all the fuses. The front driectionals/park lamps work so I don't think it's the multifunction.
To clarify the rear outboard brakelight do not come on, neither to they blink when the hazard is applied. The gas door also does not work.
The reverse and highmount lights work, but after looking at schematics they appear to be totally seperate except for a power source or two.
The blinkers blink superfast as if both rear circuits are open.
Discussion Starter #2
nevrmind, apparently when I disconnected my fuel cutoff switch I knocked the wire harness for the rear lights and fuel door loose. :eek:
1 - 2 of 2 Posts
