I'm looking for as much information as I can get about a swap between my 4.6 and a cobra 4.6. What model in particular should I buy and what other mods would need to be made to do this swap?
You'll find lots of info by searching for things like DOHC swap, mark VIII engine swap, and things of that nature. I am guesing it will answer all your questions, but if it doesn't ask what remaining questions you have after doing some reading.
You can pick up a set of EVTM CDs over on ebay. Get one for the year of the vehicle and one for the year of the engine. It will make tracing out the wires a lot easier. The swap is pretty straight forward though. Only thing you will have to work around is what exhaust you will use as in Mark 8 manifolds or a set of custom headers since the steering shaft issue. Or modify the steering shaft and use Cobra parts. Then how will you wire up the IMRCs to work. It's not a good idea to delete them in these heavy cars so you will need the added torque the produce. A window switch would be the easiest set up for you since you have a 94. You will need a chip to finish it off so it will run properly. Let me know if you need a chip.
I need a chip, but for my 95 Exploder swap. PM me lonnie so we can talk more :)
