Need a little help...
I have a 1995 thunderbird with a 3.8. Theres a Rod knocking in the motor so its time to swap.
I have access to a 2000 mustang 3.8 for next to nothing with 25,000 on it.
I would like to purchase that motor and upgrade the cam.
Will this motor fit into the Bird. Do I need to change the existing computer. And Im pretty sure the existing tranny will work.
Any thoughts or suggestions.
Thanks in advanced
i asked the same question not too long ago check out the 4.2L swap article it can be done
Confirmed V6 Nut
Since you have a 95 with a DIS in place, a 2000 3.8L ought to drop in. It is the same block. All your accessories will bolt up to it. Racecougar put a 2000 3.8L in his 94, but had to convert to a DIS since the 94 had a distributor.
Also, you'll get more HP from the 2000 engine. Enfoy!
He might not. I believe only the California cars had DIS.
DIS wasn't the norm until 96.
That's correct. Unless he has a California Emissions car, he doesn't have DIS. That means wither converting to DIS, or deleting/moving the EGR to clear a distributor.
There is a fair amount of info about this swap here on the site. I'd suggest searching for "splitport" and "splitport swap".
The engine will fit under the stock 94-95 Tbird hood, after modifying/making/moving a few brackets.
-Rod
