1 - 12 of 12 Posts
Question: Whats the difference between the GT 4.6 and the Explorer 4.6 and why people prefer the Explorer engine? I want to do the swap and i want to weigh my options.
Another advantage is that for 94/95's you can use the timing cover from your car on the Explorer motor.
Chapter Director Coordinator
so long as they are for a tbird, yes
still has PI heads.. still a 4.6... just some minor differences. alum vs iron like JR said, oil pan, front cover, intake a little different, etc
you need your front cover, your oil pan, your oil pickup tube, your front accessories, a newer style intake unless you want to try to tap the plastic in the back, a 96+ upper intake, etc etc etc
you also need to swap over the oil filter mount/coolant output piece on right side of engine
be really careful with that gasket, you don't wanna pay to get a new one.
all i can think of right now.. but there is more
i run the exploder intake with the heater core fitting in the front! If he is lucky, the yard wont hack off the flow restrictor and he can use it!
jeez, dick-oy-oh, even Tim did the front heater core fitting maniold....
frickin guy.
1 - 12 of 12 Posts
