So I took a few moments to try and track down the minor exhaust leak on the Cougar and I'm thinking it's coming from the driver's side cat. I was thinking about cutting off the heat shields to get a better idea, patching up the leak (it doesn't sound like a major leak), then reattaching the heat shields. I was wondering what might be the best way of sealing the leak. Would a high temperature epoxy hold up against the extreme heat? Or would I be better getting some sheet metal brazed onto it? The cat itself doesn't appear to be bad and with this being the 'beater' car I can't justify spending the money to buy a new cat and have it installed.
If it is a small leak and it is actually on the cat, then it is probably just a pinhold and the best way to fix it is just to weld it. They do make something called muffler cement which will work for a while, but eventually it will dry out and crack off again. If it is too big a crack to weld, or if the metal is so rotted away that welding blows holes right through it, then replacing the cat might be the best solution.
JB Weld
How does JB Weld hold up under extreme heat? :zdunno: Just an idea...
I googled it earlier and found someone mention they used it with good results on a muffler, but closer to the engine it cooked and produced a quite awful smell. I think I'll spare my nose the ailment...
Are the cats on these stainless? I would say that you should just do it right the first time and weld it. If it is only a small leak, then it should be easily welded. Just make sure to use the right welding wire/electrode.
