1 - 10 of 10 Posts
Im getting ready to install a set of Braincoated manifolds on my car and didnt know if anyone had any good recommendations on what gaskets to use, i put fel pro on when i installed motor and there leaking, Ive found the ford racing paper gaskets but someone has also mentioned that ford makes metal gaskets.
Why not just use the OEM metal gaskets? That's what I used, no issues.
Can you still get the oem from the dealer then?
They are around 80 bucks my cost
But I've got a set of brand new oem metal ones 50 shipped or u Can get the felpro ones like 10 bucks just use copper coat never had any issues
yep, the factory style steel faced gaskets work real nice with a little copper coat sealer on them. you can also make your own from 1/8" copper or aluminum sheet as well. if you use the copper or aluminum sheet, the gaskets are reusable.
Ford OEM 4.6L Exhaust Gaskets
The Ford Part Number for these are: YC2Z-9448-CA (YC2Z9448CA)
There is only 1 Gasket per package..
These cost $120 from the dealer for all 4 gaskets..If you go OEM..Rob has an excellent price on them.. ;)
I sent him a set
1 - 10 of 10 Posts
