Last week I installed the Force II's on my 97. I'm having a problem with the pipe hitting that removable crossmember and it causes an annoying rattle. I tried to shim it with a number of items like an exhaust rubber but it melted. i also wedged a used rear brake pad in but now the whole car vibrates.
How important is that crossmember? Can I leave it off? or even bend it? Any help ? Thanks again...Chris
Doesn't that affect rigidity?
Chris, I had this problem too when I drove the car in and out of a barn it was winter stored in, it would scrape a ledge getting up the embankment.
I simply got out a pry bar each spring and reefed on it a bit forcing it down from the crossmember.
It probably gets really bad when you're accelerating (engine twisting sideways)?
Thanks for the input...I'm gonna remove it and see what happens. Thanks again, This place is a great source for info!
