Stroked and Blown
Would a true 2 inch dual exhaust system be good for about 250-260hp? I have true 2 inch duals with magnaflow mufflers and I'm noticing many here have 2.25 true duals. Is there that much of a difference? What would happen if you had about 250/260 hp and your true dual exhaust system was only 2 inches? Would it blow the pipes off, cause the engine to stall??
thanks
it would be fine and actually have more torque on an NA car than a car with 2.5" true duals (keeps the velocity up)
2.25" would be ok....keeps the back pressure needed for low end torque.
