Exhaust Question
507 Views 4 Replies 3 Participants Last post by  chunk
How's it going, to start with I removed the third cat and want to know how it would sound with the factory resonator and straight exhaust all the way back (no mufflers) ......has anybody done this?
Just cut your mufflers off and see how it sounds. If you don't like it have someone weld it back on for $20 or $30.
I'm running a straight pipe back from the third cat now and it sounds like hell. Wanted to put the resonator back on and see if I can get rid of the resonance in the car. Kinda on a tight budget too. I had a flowmaster cat back and it rotted out ......as they are prone to do:(
Umm straights from the cat back? Drone like HELL. You'll like it for 5 minutes. Then it will get old. Sounds like a damn bumble bee on the road. Sounds pretty sad if you got a V8 under there and sounds like some kids rice burner.
I agree.... Iput the factory resonator on and the factory pipe from the res back with no mufflers it sounds a good bit better (not as much drone in the car) than it did before but not exactly how i would like. The flow of money was the biggest factor. Sounds a little like wasps instead of bees;)
Thanks for the input
