Exploded 4.6L 2V Complete
1 Bolt N806155-S2
2 Fuel Charging Wiring 9D930
3 Accelerator Cable Bracket 9723
4 Bolt N804394-S8M
5 Fuel Injection Supply Manifold 9F792
6 Fuel Injector (8 Req'd) 9F593
7 Nut N806178-S2
8 Water Hose Connection 8592
9 O-Ring 391107-S
10 Water Thermostat 8575
11 Intake Manifold Gasket 9461
12 Water Temperature Indicator Sender Unit 10884
13 Engine Coolant Temperature Sensor 12A648
14 EGR Valve Tube to Manifold Connector 9F485
15 EGR Valve to Exhaust Manifold Tube 9D477
16 Bolt N804073-S8
17 EGR Valve 9D475
18 EGR Valve Gasket 9D476
19 Screw and Washer N806154-S2
20 Throttle Body 9E926
21 Throttle Body to Intake Manifold Gasket 9E936
22 Throttle Body Adapter 9A589
23 Bolt N806154-S2
24 Intake Manifold Upper Gasket 9H486
25 EGR Vacuum Regulator Bracket 9J472
26 Cylinder Head 6049
27 Bolt N804958-S2
28 Idle Air Control Valve 9F715
29 Bolt N806155-S2
30 IAC Valve Gasket 9F670
31 Bolt N806156-S2
32 Intake Manifold 9424
33 Core Plug 9A450
34 Positive Crankcase Ventilation Valve 6A666
35 Crankcase Ventilation Grommet 6A892
36 Bolt N806183-S2
37 Valve Cover Bolt or Stud Seal 6C518
38 Engine Front Cover Gasket 6020
39 Crankcase Vent Connector and Hose 6C324
40 A/C Compressor 19703
41 Bolt N806184-S2
42 Bolt N606502-S36
43 Ignition Coil 12029
44 Drive Belt Tensioner 6B209
45 Nut N804178-S2
46 Generator 10300
47 Screw and Washer N606676-S36
48 Generator Rear Mounting Bracket 10153
49 Bolt N806200-S2
50 Bolt N806155-S2
51 Crankshaft Position Sensor 6C315
52 Crankshaft Front Seal 6700
53 Bolt N806155-S2
54 Engine Front Cover 6019
55 Camshaft Position Sensor 6B288
56 Stud N806300-S2
57 Screw and Washer N806282-S2
58 Water Pump Pulley 8509
59 Bolt N806177-S2
60 Water Pump 8501
61 O-Ring 3Z728
62 Valve Cover Gasket 6584
63 Valve Cover (RH) 6582
64 Crankshaft Main Bearing Cap Bolt 6345
65 Cylinder Block 6010
66 Engine Rear Plate 7007
67 Flywheel 6375
68 Bolt N806168-S
69 Valve Cover Gasket 6584
70 Valve Cover (LH) 6582
71 Valve Cover Bolt or Stud Seal 6C515
72 Bolt N806183-S2
73 Fitting 6A648
74 Oil Filler Cap 6766
75 Stud N806356-S2
76 Valve Cover Bolt or Stud Seal 6C515
77 Head Gasket 6051
78 Dowel N806456-S
79 Oil Filter Mounting Insert 6890
80 Oil Filter Adapter Gasket 6840
81 Oil Filter Adapter 6881
82 Oil Pressure Switch 9278
83 Oil Pressure Sensor 9278
84 Stud N806514-S2
85 Bolt N806156-S2
86 Oil Bypass Filter 6714
87 Bolt N606523-S
88 Oil Pan Gasket 6710
89 Ignition Wires 12259
90 Bolt N806155-S2
91 Ignition Coil Bracket, LH 12A166
92 Ignition Wire Separator 12297
93 Stud W701624-S
94 Ignition Coil 12029
95 Bolt N606502-S36
96 Power Steering Pump Pulley 3A733
97 Power Steering Pump 3A674
98 O-Ring N806176-S2
99 Oil Pan Baffle 6687
100 Oil Pan 6675
101 Oil Pan Drain Plug Gasket 6734
102 Oil Pan Drain Plug 6730
103 Bolt (6 Req'd) W701240-S309
104 Nut W701575S
105 Exhaust Manifold 9430
106 Bolt N806139-S2
107 Washer N806164-S
108 Camshaft Sprocket 6256
109 Camshaft Sprocket Spacer 6265
110 Camshaft Bearing Cap (Front) 6B280
111 Camshaft Bearing Cap (Rear) 6B280
112 Bolt N806070-S
113 Camshaft 6250
114 Cylinder Head Bolt 6065
115 Oil Level Dipstick 6750
116 Bolt N806155-S2
117 Crankshaft Main Bearing Cap Bolt 6345
118 Bolt N806513-S2
119 Heater Water Hose 18472
120 Bolt N806070-S
121 Timing Chain Guide 6K297
122 Water Bypass Tube 8555
123 Dowel N806040-S
124 Timing Chain Tensioner Arm 6L253
125 Timing Chain Tensioner Arm 6L253
126 Bolt N806070-S
127 Timing Chain Guide 6K297
128 Dowel N806040-S
129 Crankshaft Main Bearing Cap Stud 6345
130 Crankshaft Rear Oil Seal Retainer 6335
131 Crankshaft Rear Oil Seal 6701
132 Bolt N806155-S2
133 Orifice and Strainer (Part of 6049)
134 Spark Plug 12405
135 Valve Tappet 6500
136 Rocker Arm 6564
137 Valve Spring Retainer Key 6518
138 Valve Spring Retainer 6514
139 Valve Spring 6513
140 Valve Stem Seal 6571
141 Core Plug N804811-S
142 Timing Chain Tensioner 6L266
143 Bolt N606543-S2
144 Intake Valve 6507
145 Exhaust Valve 6505
146 Crankshaft Thrust Washer 6334
147 Crankshaft Main Bearing 6333
148 Exhaust Manifold Gasket 9448
149 Piston Compression Ring 6150
150 Piston Compression Ring 6152
151 Oil Ring Rail 6159
152 Oil Ring Expander 6161
153 Oil Ring Rail 6159
154 Piston 6108
155 Piston Pin 6135
156 Bolt (2 Req'd)
157 Connecting Rod 6200
158 Connecting Rod Bearing 6211
159 Ignition Coil Bracket, RH 12A166
160 Connecting Rod Bolt 6214
161 Stud Spacer N806180- S
162 Bolt N605904-S
163 Oil Pump Screen Cover and Tube 6622
164 Oil Pump 6600
165 Bolt N606021-S
166 Bolt N605892-S2
167 Timing Chain 6268
168 O-Ring 87038-S96
169 Crankshaft Sprocket 6306
170 CKP Sensor Pulse Wheel 12A227
171 Crankshaft Pulley 6312
172 Crankshaft Pulley Retaining Washer 6378
173 Crankshaft Pulley Bolt 6A340
174 Woodruff Key N806201-S
175 Crankshaft 6303
176 Lower Crankshaft Thrust Main Bearing 6337
177 Lower Crankshaft Main Bearing (4 Req'd) 6333
178 Main Bearing Cap (5 Req'd, Part of 6010)
179 Crankshaft Main Bearing Cap Stud 6345
180 Belt Idler Pulley 8678
181 Stud Bolt
