1 - 20 of 74 Posts
hey, i been wanting to do explorer block and pi stuff. i hurd since i have a 95 a 02/03 mountaineer or explorer block would be the best. what else should i be looking to get with the motor..pistions, crank, ect? i wanna do it right the 1st time.
that depends on what your plans are with it later.... sc/na/nitrous etc....
If you get one from Greenleaf or similar place, it will be complete. Unless you are looking to build the heck out of it then that is all you need.
Refrigerator Raider Hater
Yes, 02-04 Explorer will get you an aluminim block, you re-use your stock oil pan, front cover and valve covers.
be forewarned, if you get an early production motor, it may have a 2000-2001 build date at the '02 trucks were brought out in mid-ish 2001.....so, dont get scared if you see such a build date.
k..well i prolly dont wanna build the crap outa it. so if im not. the explorer pistions crank ect would stay in there? and use my 95 bird stock oil pan, front cover and valve covers. right?
I understand using the stock front cover and oil pan, but why the stock valve covers? Why not use explorer Valve covers?
He can. The covers on my Explorer motor were identical. I swapped them out to keep them clean in case I want to powdercoat them later.
allright. but ima do pi at the same time. so wouldnt i use those valve covers?
ic. well are the explorer heads cams and intake as good as like a 99+ mustang?
Yes. That is why they are such a great swap. You get all the benefits of a 99+ Mustang motor but 80 pounds lighter.
alright kool. so if i wanted to do better tb/plenum? what year and car could i get that off of?
Discussion Starter #15
ya aftermarket off of what. like stang...
1997-2004 Ford 4.6 2V
Discussion Starter #17
oh allright kool. what else should i look for when gettin this motor. should it have everything like fuel lines ect.
02 Explorer Pioneer
You will need to either use 96-97 Tbird fuel rails or I think someone has used vic rails. If you do a search on my name or Palmguy going back 4 years you should find a post detailing everything about the swap including wiring harness changes
Discussion Starter #20
k what else should i think about doing while the motor is out, frount sway bar, new motor mounts, headers. what else? and do they make headers for the explorer?
1 - 20 of 74 Posts
