1 - 19 of 19 Posts
I am in the process of doing the IRS build up as posted on MN12Performance.com and am just dreaming here but I wanted to get you guy's opinion as to if you think this will work.
Currently is only have 4 bolts holding our rear subframe to the car. It has been told to me by countless people, anything over about 600 ft*lbs of torque is going to rip the rear subframe and the four bolts out of the car.
Here is my thinking. I am thinking of fabbing up a four more anchor points to the frame of the car by using the bushings off another subframe from an MN12. This will give me an 8 bolt anchor system instead of 4. The places I am thinking of mounting them is right above the rear upper control arm on the top of the subframe thru the trunk(with extra supporting back there) and extend the other two forward to the front of the car, about 1.5-2 ft in front of the front mounts of the subframe.
I am working on a motor application that will need this support. Do you guys think this will help do what I want it to do?
I am still in the process of the build up on the IRS. I am working on some additional bracing to the control arm brackets.
When I finish this project, then I am planning on then working on the additional anchors for the subframe to the chassis.
I was wanting to get some ideas from anyone hom had ever thought about doing or has done this before.
Fusion, PM me your email address and I will send you some pics of what i end up doing.
I pm'd you 2x, the first one i did through the window linked out of hotmail and i dont think it went through.
BUMP, come on guys, someone has to have an opinion on this.
I have seen the pinion brace from mn12performance. Rich has done a very nice job on it.
I plan on fabricating a brace similar to that of a pinoin brace but with twice or three time the support for the control arm brackets.
with the kind of power that your talking about i want to know what your going to to about the halfshafts. With over 600 ft/lb of torque i can see those breaking easily before the subframe gets ripped out. Especially if you run slicks and hook up real nice a few times. Also did you plan on an auto or manual
Horse power isn't what breaks the half shafts. Torque is what will break them if your rear end starts to flex and induces the suspension into wheel hop.
The purpose of the extra rear sub frame support is to anchor the sub frame to the unibody preventing it from flexing. The flexing that occurs from the torque is from the action of the sub frame trying to lift the car off the ground by rotating it on the back wheels under a sudden acceleration. Our stock set up is very weak. Under heavy acceleration, our sub frame tries to pick the front end of the car up, but the mounting brackets to the control arms flex causing the lower control arms to start "dancing" thus inducing wheel hop.
By completely reinforcing the sub frame at the mounting brackets so they will be unable to flex will keep the control arms stable. Thus as the sub frame is reinforced, more torque can be applied to the rear end. To keep the sub frame, itself, from flexing, additional connection points need to be added between the sub frame and the unibody.
I am also changing to the GKN axels. I am in the process of trying to set up a group purchase on these axels.
I am shooting for the range of 800+ Ft*lbs of torque.
I have started fabrication on the subframe itself. I am currently giving the subframe more internal strucure and I was planning on finishing this part up last week, but work has prevented me from that.
I haven't taken any pics yet due to the design being updated every time i work on it. When finish up with this part, I'll get some pictures posted up.
I am very interested in this halfshaft purchase. I've got a high power engine project in the works and axles are one of my concerns. Keep us informed on that purchase. Do you have any more info or a link or something on these halfshafts
Unfortunately I have gotten no response in approval or unapproval of the purchase from the moderator for Group Purchases.
Untill I can get a yes or no, I do not want to spend a lot of time getting it together for no reason. The only info I have gathered so far I have listed on a this link
http://forums.tccoa.com/showthread.php?s=&threadid=33566
There is one change, The price of the shafts may be a little higher than I had originally been posted.
As soon as I get a response, I will move forward from there and let every one know what the deal is.
I had contacted GKN when they started producing half shafts for the Cobra and lincoln LS...After awhile communication was just lost..Thier Cobra shafts are nice quality and worth the price. Now those shafts with 31 spline end for the differential would be great..Keep us informed:O)
Discussion Starter #16
I am getting closer and closer to finishing it up. I have the control arm mount braces welded on and have almost completed a upgraded pinion brace. Mine will have six points of connection unlike the four point connection on retail pinion braces offered for cobras and tbirds.
I have a race engineer buddy of mine looking at it Monday(3/8) to see if there are any more improvents I can make.
Next is the fabrication of the upgraded rear tortional brace. This will have four points of connection unlike the two points of connection being sold.
I have welded and cut off things several times, so I don't want to post anything yet until the finished product. Anything I have done so far is subject to change. As soon as I get something I know for sure I am not changing, I will post pics.
Discussion Starter #18
I am kind of at a stand still at the moment. I am going with a new set of GKN axels and I am trying to get the larger 18 point cv joint axels to fit, but with out having them, I don't know what the demensions are. I also just spent the last few weeks trying to get the nightmare of a KVR brake system on my car and working for the Autofair in Charlotte NC this past week end; the back brakes are still not working right so I still have work to do on them to even get the car drivable.
I have got the front subframe bracing complete and will have the rear bracing finished up hopefully by the weekend, but untill I get the axels, I will not have the project fully completed untill they come in.
Discussion Starter #19
Here are some pics of what I have done so far. The bracing I have added is going to have to be modified due to the new GKN axles may car is going to get.
The pinion style brace is complete but I do not have picture of it on the subframe yet. The rear tortional brace is still in the process of being made. The delay of not having the axels has put me a little behind on completeing this project. It is just a work in progress.
http://members.tccoa.com/fordthunder/Copy of 000_0068.jpg
http://members.tccoa.com/fordthunder/Copy of 000_0070.jpg
1 - 19 of 19 Posts
