1 - 2 of 2 Posts
Are the front passenger fenders on the t-birds the same wether u have a power antenna or not. I am asking coz i noticed that in one of the pics on this site the power antenna is bolted to like a lip on the back part of the fender. Does the fender with the manual antenna have this same lip for the brace that holds the bottom of the power unit. The car wash broke the mast of the antenna i had which was an aftermarket and i don't want to go through trying to remove the piece of bolt that is in there unless there is an easy way. Any suggestions would be greatly appreciated. I have a 96 Lx
Yes, they are the same. The only difference in MN12 fenders is between 89-95's and 96-97's. The 96-97's have the holes drilled in them for the body cladding. In your case, you could use any 89-97 MN12 fender, you would just have to drill the holes for the body cladding if you used a 89-95.
-Rod
1 - 2 of 2 Posts
