where is a cheap place to get a decent amount of fiberglass? also is it any more difficult than using bondo(which is easy)? i need to repair my old 90 cougar has tons of rust spots. and i need to make a hood scoop. :D
thanks all help appreciated as always
edit: Hey scott, how much fiberglass did you use for your scoop on frankencougie?
You can usually get the the resin and material from any auto body supply store. And when you use fiberglass your gonna be using bondo too anyways. Fiberglass will patch holes, bondo smooths everything out.
