Its got 90K on the clock. Needs upper control arms, but that is about it.
I may be wrong, but through all my years f-ing around with these things, restriction is restriction. Sure 80mm is more than enough to supply the needed air for the power the engine will make. But to make more power you need to get more air into that same engine. The air has to move more efficiently to acheive a benefit. I look down the throat of the stock MAF and see a full cross bar. I look in the 90mm and see a partial cross.
And, its not all about peak power. Better throttle response and possibly more power under the power curve, even with the same peaks, could be gained.
One way to find out for sure..........................
Richard
