Geek w/Gearhead Complex
After a spot check and thinking it was a sticky caliper (rotor was warped in a very strange manner, 3 levels, inside was fine, middle was a step down, outside was...interesting. Figured the piston was bad) -- wrong, bad hub.
More importantly was how/what lead to this hubs failure. We dismantled the rear pass. side when doing a diff swap some time ago. When it was put back together, an impact was used (and for the record, I HATE impacts) to put the nut back on the 1/2 shaft and this, in turn, caused the problem.
The nut was seemingly secured properly (500ft/lb impact, but not on full), however, in doing so, we assume it loosened a lot of the rust in that area and this give it room to move and loosen itself slightly allowing the hub to become mobile, wearing the bearing down in a strange manner and effectively, destorying the hub and bearing.
Anyway, thought I'd share. I'd recommend going BACK a few days later and checking that nut. Amazingly, my car rides a lot nicer now :)
Thyg0d said:
They usually do when everything is bolted down correctly...:D:D:D
Just had to...
Great to know....
//Per
yep, so you have to add one to the 'obvious' list...
things work better when...
- plugged in
- turned on
- turned up
- assembled correctly
:zbash: :zbash: :uppoint: :uppoint: :rofl: :rofl: :crazy: :crazy:
You just eliminated ANY ammunition that you might have vs. my cars and their slowness.... :rofl: :rofl: :rofl:
Conversations will henceforth go like this: You, “Your cars are slow…” Me, “Yes, but at least I don’t use an impact wrench on a half-shaft bolt…” :D :rofl: :thumbsup:
wasn't me that put it back together. I've always hated impacts and now I have even more reasons. (I call 'em cheater tools)
oh and just to add stuff, I just noticed. You = 2x fubar age (well, damn near anyway)
...and yes, you = teh sl0w ...I just need to stop letting people help me work on my car
