My flash to pass doesn't work. Push MFS forward, it locks and brights come on. Pull toward me, no flash. Just wondering if there are any relays, fuses, wiring to check before replacing the MFS? Thanks.
That's partially correct... It's missing and fall right out when a new fuse is placed in there. If I hold it up there I can flash to pass. Kinda hard to drive with my finger on the fuse box though. I'm thinking the terminals are bent.
There was a CB radio in there at one point the PO gave me the radio and the speaker was down by the accelerator pedal. I took a small flat head and tweaked the terminals, fuse is in there.thanks for the help, I've not used the lighter socket because you need the armrest open to plug anything in, so it's useless.
