me too...
My hazard lights never worked. When I engage the hazard switch, nothing happens. When I turn it off there's about a 75% chance that my turn signals won't work. I have to turn the hazard switch on & off a few times to get the turn signals to start working again.
Don't know if the switch is bad or the hazard flasher (is there one for turn signals and one for emergency?) is bad. Tried to find it -- sounds like it's buried behind the instrument panel.
Looking at the shop manual, it looks like there's only one electronic flasher unit which is shared between trurn signal & hazard. So either there'd be a problem with the hazard switch (most likely because of turn signal issue) or the multifunction switch. Guess I'll be going without hazard lights until next year
