Flasher Relay Location? Pics please?!?
Ok, I'm having a hell of a problem;
I have troubleshot the problem and it turns out it is the blue/white signal wire. I believe that it is not making a good connection, and thus I need to know WHERE it leads to, and where it'd be connecting, because there is a poor connection there.
Still need to know where the flasher relay IS at... can't find it under the dash, would like to avoid dismantling the dash if I can.
What's going on is that I am not able to use my passenger side forward turn signal. It kinda blinks on for one pulse and then quits, but the driver's side works just fine, and the hazards function correctly. It will also flash the rear blinker if you have the parking lights off.
I am pretty sure it isn't so much of a problem with the wiring harness as it is with what I am suspicious of being the flasher... but I could be wrong. Anyhow, where the hell is that damn flasher? Chilton's says it's under the dashpanel on the right but I couldn't find the damn thing. Does anyone have a photo of it?
Ghost
Ghost
