I have been searching all night, I have found a lot of great info on the 02-04 explorer engine to 95 t-bird. This is what I have found:
96/97 -
fuel rails with FPR
throttle cable
throttle cable bracket
forward fuel lines (from filter to rails)
EGR tube
PI parts
Mustang PI intake with updated cross-over
intake gaskets
oil filter/lower rad hose housing gasket
(your choice of torque converter, Flexplate, and hardware (might as well with the engine out)
Now my questions are: Do I need to get another flex plate and T/C if I all ready have a new one? "Mustang PI intake with updated cross-over" How will I know what that is? Is there a part number for that? Other than that...Is 2000.00 what I shoul expect to spend on all this stuff?
Thanks Eric
Chapter Director Coordinator
just get a PI intake with the aluminum coolant crossover and you'll be set
you should be able to use your flexplate on the exploder block, unless you get a different TC, some require a smaller flexplate
if you need the 96-97 throttle cable and bracket i will have one available soon :)
FYI, the exploder is a romeo motor, so if you go with a stang 11.25 convertor, just get a stang 6 bolt flexplate. The exploder one wont work.
Refrigerator Raider Hater
Way less than $2000, more like $200 once you get the 96-97 stuff you need.
You don't need a new flexplate or TC. If your going to pull the engine anyway, you might as well.
