1 - 2 of 2 Posts
I have a 95.4.6 Bird. Will this torque converter fit my flexplate directly? Or do I need the one for the markVIII/marauder? Should I go with a smaller converter? This one is 12 inch with 113/8 bolt circle or should I go with the 10 3/8 bolt circle with an 11 inch converter? I'm assuming the smaller one would attach right to a markVIII flex Plate.
https://www.jegs.com/i/FTI-Transmissions-&-Converters/107/SB2400DE/10002/-1?CAWELAID=230006180001090990&CAGPSPN=pla&CAAGID=15769068431&CATCI=aud-545831090306:pla-215314521911&CATARGETID=230006180037476132&cadevice=m&jegspromo=thirdparty&gclid=Cj0KCQiAkMDiBRDNARIsACKP1FGCVUmWweyd5U0OvWKO51aRxeX5GFqmq2BJk7s6Z2BfieQmlZPi29saAphIEALw_wcB
Typically, anything other than the stock converter needs the MK8 flex plate.
Al
1 - 2 of 2 Posts
