1 - 12 of 12 Posts
Most of you guys know me... I did the J-mod awhile back, love it!
My question is referring to durability of our tranny. My 1-2 is pretty harsh, and if do a manual shift, it's VERY firm (car jerks forward a bit). I can't help but feel like something is going to snap one of these days.
What do you guys think? I trust Jerry very much, but my car is my baby, and I can't help but worry that I might damage it with the really hard shifts.
Or... is it simply that we are so ingrained with the smooth shifts, that it just feels wrong with the hard shifts?
-Chris
Yep, my 1-2 is extremely harsh also. Next time I do a filter change, I'm going to put the top spring back on top of the accumulator....
I replace the spring as well. It is still very firm with the spring in place.
And you are right, all those really harsh shift DO break things. :(
Yea, I am impressed that the cars have loops, considering the proximity of the gas tank, but they don't help with broken spiders gears, axle joints and stub shafts in the tranny... :D
it's a matter of taste. personally i like mine without the lower springs... but if youre worried then put them back in- no big deal. when i did the one for our older vic, i left the springs in... for the softer, more luxury feel. As long as you don't WOT at every stop, I dont think it would cause many problems. However, any of the higher settings are excluded from that statement - as with all shift kits, it does stress the axle and especially u joints. All things performance are a sacrifice, its just a matter of what you're comfortable with.
High-Mileage 4.6L Thrasher
If you pulled the upper spring..you need to fix that anyway..the upper stays put,and the lower comes out on the 1-2,and no springs for the 2-3..
JL
JL
i pulled the bottom one... and took out the 2-3
BTW, i'm thinking about getting my stock heads p&p... if you don't mind my asking, how much did renegade charge for that? (I think that's where you had them done... if i remember correctly)
Good...what hole HP spec did you use to drill?
JL
JL
drilled to mild i believe...
or could have been mild... I remember I noticed there wasn't much of a difference between the two... maybe i did 300... it's been awhile... :)
Well,that's not gonna harm anything...I drove my car drilled to 300hp settings for almost 100K miles,and those that know me...know I drive like DanU does :headbang:
The car has the original halfshafts,rear hubs,rotors,bearings,LCA bushings,etc..those never been apart-and all of those parts are still good with 225K miles on them.
I replaced my diff and driveshaft at 160K miles,but it wasn't becuse they were bad...
JL
JL
Ok... good to know! :)
I'm intending to build my car up N/A... and gonna try to hit your numbers... :) ugh.. your my hero or something ;)
BTW, you ever gonna make parts again? I'll be in need of them sometime soon, otherwise I'll have to buy them from KB, if i had some CAD drawings or something, I'd have my uncle make them. (He's a welding instructor).
1 - 12 of 12 Posts
