1 - 2 of 2 Posts
got a really good deal on one of these, would it work on a stock 4.6? what else would i need to install it?could i just switch it out no problem? what would the gains be?
which is better the lightning 90mm maf or the 02 gt 80mm stock maf?
tried to use search function but kept coming up with zero results.
It will work, but you will need to get your computer tuned for it to work properly. You will also need the intake tube and air cleaner box assembly.
As far as close to stock n/a setups, you'd be better off with the 02-04 80mm Mustang GT's MAF; the 90mm Lightning MAF is more for a supercharged engine and the GT's isn't.
1 - 2 of 2 Posts
