1 - 1 of 1 Posts
I have two Ford Service info DVDs, One dated April 2002 v8.0, and the other August 2002 v12.0. For some reason, none of the elecrtical documents work on any vehicle after 2000 or 2001. When I try to open one (Wirind Diagrams/Components/{select year/vehicle/component), then select one (023-004:Engine Controls (4.6L) for example), on one PC, I get a blank screen, on another, I get a "File does not begin with '%PDF-'." Error, and on another, which has Acrobat Pro, it tries to open with that, and when I go to look at a connector, it basically locks up the application.
Do any of you have the same or similar DVDs, and if so, have you ever had these problems?
Thanks
1 - 1 of 1 Posts
